I type a word in the search box and select “search in all projects”. Then I select an other project in the sidebar.
The selected project is displayed but with “No notes matching … in this project”.
It’s a bit disturbing as the search box has been emptied.
Either the search is canceled or the search text is still displayed.
Aganda 9.1.2 on Catalina.
HTH, Pascal.
Can you check whether you are using the latest 9.1.3 version and whether it still happens there?
It’s ok with 9.2.1 (the searched text remains displayed).
Thanks, Pascal.
Great, thanks for confirming!
