Just using Agenda on my Mac and about to make a screenshot and then import it into a note… and then I found the “Capture Selection from Screen”… and it worked great! I had no idea it was there.
It’s only a small thing but I wanted to feedback how excellent Agenda is. Thank you for all your work.
Thanks. I actually don’t see that listed in my note options when I bring up the menu. I don’t see Import Image or Capture Selection. Is there a reason, setting, why I wouldn’t see those options?
Interesting, it seems to depend on what macOS version you use, the screen capture menu item seems only available on 10.12 and 10.13, on mojave you’ll find this menu:
