What I did: I am in Today View, with two notes showing up. Opening the note (with todays date assigned) and tapping on „remove date“ does nothing, there ist still today displayed and the note remains in Today View.
Things that might be helpful to know (Agenda version, OS and model, etc): iPda Pro 11, latest OS, latest Agenda version.
Does it get removed if you move away to another project and back again? I think the search index just needs refreshing. It may also be a bit jarring to immediately remove the note as soon as you change the date.
I confirm that this issue exist as of January 27, 2019.
It affects notes with “Today” and future dates.
Example: I have a note with date for “Tomorrow”. I clicked on the Calendar icon in the note, select “Remove Date” and the Calendar pop-up disappear. The note still show “Tomorrow”
If you tap the calendar icon top-right on the note, you should be able to unselect the date it is attached to, and then click the button bottom-right to commit that change.
