Guys- couple of issues -
In the 1st, when I select the ‘saved’ Reminder in the side bar to edit by using ‘Show in Reminders, nothing happens. Is it supposed to open Reminders app (in order to edit)?
And 2nd, if I select the Reminder symbol in the IN the Note, should that also open the reminder in the Reminders app? If so, it does not.
