- Used Insert -> Reminder, then tried to select a reminder calendar
- Each reminder calendar is listed twice
- Each reminder calendar should only be listed once.
- Version: 12.0.2 (181) Mac App Store
- OS: 11.2.1
- Model: MacBook Pro (13-inch, M1, 2020)
That’s very odd, are these iCloud reminder lists?
They are shared via iCloud. I migrated from the old MacBook Pro to the new one and somehow ended up with each calendar being duplicated on the new machine.
Does it help if you:
- quit Agenda
- in Go to Folder under the Go menu in Finder, paste:
~/Library/Group Containers/WRBK2Z2EG7.group.com.momenta.agenda.macos/Release/Application/DerivedInfo
- make a backup copy of the
CachedInfo
folder, then delete it
- start Agenda
Do things works as they should after that?
Just tried that. Still each calendar is shown twice. I also deinstalled Agenda (using appcleaner) and reinstalled. Same behavior.
Very strange, do you perhaps have two accounts configured in the system preferences? Does the system calendar app only show a single calendar set?
System calendar app shows only single calendar set.
