What happened: doesn’t move to the top in “on the agenda”
What I expected: Move it to the top
Things that might be helpful to know (Agenda version, OS and model, etc): MacOS. I see the earlier posting in 2020, but it seems like nothing happened to this issue.
Thanks for the report. Is your On the Agenda overview grouped, eg by project? The pin only applies in the natural order of the notes, so when an overview is grouped, a pinned note will not jump to the top.
If it is not grouped and the note still stays put, let us know and we will take a closer look.
If you tap on the project title at the top of the list of notes, and then the button top-left, you can change the grouping.
Many searches I have I want to have tasks or items that specifically referring to the item at hand (whether they are tags or search words), but often I ended up with other items or spurious entries which makes it difficult to focus on what I really want. So, it’s really search results I would like to see improvement.
See below.
I’m searching to Tag “LSI” but the results are quite mixed.
The filter options are combined with OR. So a paragraph shows if it has the tag, or if it is unchecked. That is why you get the mix. There isn’t a way to say “tagged AND unchecked” in the filter at the moment.
Thanks for confirming. Yes, I think advanced search where we have an option to use AND, OR, NOT would make the program lot more effective for me and others.
