Recently I’ve tried to put a path to a destination on my Mac in a note without any luck! Is there a way to do this?
Easiest is to drag the file, and hold in CTRL as you drop it. That will create a link to the file.
To actually manually create a link, you would need to use a file URL. Eg.
file:///Users/drew/Desktop/file.txt
I have tried it & it worked ! Tanks mate, much appreciated.
Glad to hear it!
For next level linking to and from everything in your digital life gotta throw in a recommendation to look at Hook.
We are working with Hook to get better support there for Agenda too.
