Note ID changes when note is moved?
I’ve been using Claude to add Agenda links to documents in other apps. Claude claims that if a note in Agenda is moved from one project to another, it gets a new note ID, and because of this an Agenda link to that note that was copied before the note was moved will fail after the note is moved.
Is Claude right? Is there a work-around.
Yes, it does change the note-ID. Also the date it was made.
And no, I haven’t found a workaround yet.
Rob
Yes, that’s right. When you move a note to another project, Agenda makes a new copy of it in the destination, with new identifiers. So a link copied before the move can’t find the note any more.
A workaround is to link by title instead:
agenda://x-callback-url/open-note?title=My%20Note%20Title
The title must match exactly, with spaces written as %20. That link keeps working after a move, as long as you don’t rename the note. It works best if the title is unique.
We should make links survive a move. We’ll take it along.
