Move project to different location shortcut action
Hi there :wink:
Would it be possible to have an apple shortcuts action that would move a given, selected project to to a specific location. Essentially that would be the equivalent to the move notes action that already exist.
I would love to build an automation where projects are put into subcategories if the the main category they reside in exceed a specific limit. Then the projects will be sorted into categories for the quarters (from the creation date of the projects). This is only for organisation purposes.
Cheers,
Dominik
Thanks for the suggestion. There isn’t a Shortcuts action to move a project yet, only notes. We’ll take it along.
On the Mac, you could do it with our MCP server instead. It can move a project into another category, so an AI client like Claude could do the sorting for you. You turn it on in the menu Agenda > Integrations.
