Modify Smart Overview criteria
What I did: Created a smart overview
What happened: Unable to modify origianal search criteria.
What I expected: Is this possible? Or do I need to delete the smart overview, and start again? Deleting and recreating can’t be the official way to modify it, can it?
Things that might be helpful to know (Agenda version, OS and model, etc): 23.2 MacOS 26.2.x
thank you.
You are right, at the moment you have to delete the smart overview and save a new one, there is no way to edit the criteria of an existing one. It is a known pain point, and making saved searches editable is on our list.
Sorry for the trouble.
Gotcha. Good to know. I would suggest adding that bit of knowledge to the documentation for smart overviews, so that the next person doesn’t spent time banging their heads against the wall searching for how to modify it.
Thank you for the quick response.
That is fair, and you are right that it should be written down.
In case it helps, we just released full User Guides for all languages we support on our web site. You can find them here: Agenda User Guide
