Missing Check for Updates option
beta
preferences
#1
I dont have any “Check for updarte option”?
Help us Beta Test Agenda
#2
That’s probably because you use the Mac App Store version, the version you can download from agenda.com does have it.
#3
Darn. I thought that might the case. Can I just replace the one with the other?
#4
Yes, that’s no problem, make sure you have create an agenda account in the MAS version first, then download the app from our website and log in with your account again.
#5
Sweet. All good now. Thank you!
#6
The download button on agenda.com page has no link. Is it only me ? Thanks. Julien
#7
The download button on agenda.com1 page has no link. Is it only me ? Thanks. Julien
Which browser are you using? It downloads fine for me, are you using an ad blocker?
#8
I’m using Firefox. And I do have an ad blocker. Let me try to deactivate the ad blocker then
#9
The deacivation of the ad blocker did not do it. But I tried with Safari and it works. Thanks for your help. Best Julien
#10
I use Safari and the button does not work for me.
#11
Are you using an ad blocker?
#12
It finally worked but after trying at different times. Then, it became available on the App Store. When will the iOS version come out. I urgently need it.
t.
#13
Glad to hear it worked in the end, regarding the iOS version, see this forum post:
