I want to use markdown and it only works on Headers # I cannot use > or other… I am using Ulysses as my note taker and I could only change if it supports full markdown and sync across ipad and Mac
Agenda is not a markdown editor like Ulysses. We support markdown shortcuts, but we do not store the results in Markdown. They are just typing shortcuts.
> is not supported yet. We don’t have a formal quoted text style. We instead support indentation of all paragraph styles.
We can consider supporting it in future. For now it is quite easy just to use CMD-] to indent a block.
If you want a true markdown editor, you are probably better with Ulysses or Bear. We did not set out to create a markdown editor, though we do want to have good Markdown support (shortcuts, import/export).
