I’m beginning to use “link to Calendar” but would like to NOT import the metadata from the Calendar event. It would be nice to set the option in Preferences. Any advice?
It’s indeed a preference option we’d like to offer in a future update. In the mean time, if you make sure you create a new note and add some content, then link, it won’t import the metadata.
