Hello,
I was just wondering what you think about an (permanent) optical divider or a frame around each note.
Having several expanded notes in the list view makes it little bit difficult to find the end/begin of a note.
I thought about the same/similar gray thin line like of a selected note. It is not a object which disturbs, the minimal look and feel is the same. But it helps to keep a better overview.
Greetings,
Claus
We will add the ability to manually add horizontal dividers, but won’t change the visual look in terms of note separation from how it is today.
hi just make it an option… good in some cirumstances and not so in others… love the floating minimal feel
