When I use the generated Markdown e.g. in MailMate (or other Markdown processors), a paragraph following a preceding bullet point is incorrectly merged into the bullet point.
A bullet point merged with the following paragraph.
Bullet point and the following paragraph should remain separate. Actually, all paragrapsh should always be separated by a blank line in Markdown export.
Agenda 2.1.1, macOS 10.13.3, MacBook Pro 13-inch
Hi, sorry to nag you but this should be relatively easy to fix, and I am running into it quite often, so it’s quite tiresome. Could you please have a look at it? Thanks in advance.
