iCloud Sync does not work since iOS 13 update
What I did: Updating my iPad to iOS 13
What happened: All documents are gone, Agenda does not sync anymore. Other devices are not in trouble.
What I expected: That everything would work as normal :wink:
Things that might be helpful to know (Agenda version, OS and model, etc): Agenda version is up-to-date.
iOS 13 unfortunately seems to have a lot of issues with iCloud. We have seen these in multiple apps, not just Agenda.
Things you could try:
  1. Switch iCloud Drive off, and then on again on the iPad
  2. Sign out of iCloud, and then back in again
  3. Delete Agenda on the iPad, and install again (assuming you have no important data in the app)
  4. You could try a hard reset of the device. See the ā€œhard resetā€ sections of this link https://www.lifewire.com/how-to-reset-iphone-2000288
Sorry I can’t be more concrete. It seems these issues are quite random. Some people have them, and others don’t. I have also seen them be fixed by trying things like above.
Thanks for your help. Signing out and in again helped.
Keep working on your great app !!!
All the best,
Heiner
Ah, great to hear that worked!
