Hello,
When I paste some text with # or @, they becomes tags or persons with a specific rendering.
As it isn’t expected in this case, how to deactivated them without deleting them?
Thanks, Pascal.
You can use a backtick ( ` ) surrounding the symbol and word and it won’t convert to a tag or person. It will convert it to Fixed Width text, though.
Typing this:
Becomes this:
This is an #example.
Thanks Eddie for your tip, it helps.
One tick ’ at the beginning works also: '#toto.
If I have already tags or persons already displayed, I add a carriage return just after the special sign # or @ and then it is deactivated.
HTH, Pascal.
