I see the “note->make tag” menu item, but it’s grayed out and I have no idea why.
Sorry, but I have to ask: Do you actually have a note actively selected when you open the menu? The note should have a background and border to match your selected colorscheme.
You need to have an insertion point in a note. It will insert a tag in the text, so the text does have to be selected ready to type.
How do I tag the title?
You can’t currently add tags to the title of a note.
Ok, thanks for the info.
I’m a little concerned that the first two things I tried aren’t possible. :.
