- I select some text
- It takes on a green background
- I use cmd-shift-1 to set a highlight
- the text remains green backgrounded
- I click away
- the text is now highlighed red
This is the final outcome I want, but it’s slightly weird that there’s no visual indication that the text has been highlighted until I click away, so sometimes I’m not sure if I’ve used the correct keyboard commands.
Could the text adopt the selected highlight immediately it is applied?
