Go to linked note not working
What I did: select a calendar event and then go to linked note
What happened: nothing
What I expected: to go to the linked note
iPhone 15 Pro Max
iOS 18.4 (22E240)
Latest Agenda as of 4/4/25
I have a screen recording but it won’t let me upload it due to the file size
What might be happening is that the connected note IS found and active, but the window hasn’t scrolled to the note. This sometimes happens to me - or certainly used to.
Can you send the recording directly to drew@agenda.com?
We had an issue like this, but it was supposed to be fixed in our latest release. Are you absolutely sure you have that installed?
Will do! And yep, I’m sure. I downloaded it on 3/28/25. I can send a screenshot showing that as well.
Got the videos. Thanks! Will investigate.
