What I did: While editing a note, I use markdown formatting to create a heading. Then I hit enter to start typing the next line.
What happened: The next line retained the same heading formatting instead of auto-changing to body text.
What I expected: I expected the next line to auto-change to body text for streamlined writing. This is typically what happens in other note-taking applications.
Things that might be helpful to know (Agenda version, OS and model, etc): I’m using Agenda on MacOS, version 9.1.1, downloaded through the App store.
Note I’m not sure if this should be “Support” or “Feedback”.
