What I did: trying to use the Reminders integration
What happened: on both MacOS and iOS my Reminder Lists are not visible. On the Mac I am prompted to check my Internet Account settings to ensure that I have Reminders in my iCloud account (I am syncing Notes between devices using iCloud). However, this is the case. I also have allowed Agenda to access my Reminders in IOS and MacOS.
MacOS - Agenda 6.0
iOS - whichever is current today
thanks,
William
On both devices can you verify whether in the Settings/System Preferences > Privacy indeed Agenda has access to reminders? Next, can you try the following on each device:
Does it now allow you to create a reminder?
Hi Alexander,
the problem seems to have disappeared as mysteriously as it appeared. Perhaps been a conflict between different mobile device versions? I checked my iPad and found it working there - then went back to the Mac and iPhone and found it now working as expected there as well. Crazy eh? I will keep an eye on it and let the community know of any untoward behaviour. Thanks for the great support!
William
Ah, strange, well better this way
Let us know if any issues return.
Best wishes,
Alex
