OK thanks … that works … bit awkward but I’m getting the hang of it. Thanks for helping out. Deb
Is it possible to link to a file in iOS? You mention that it only works on the Mac.??? I need that feature on the iOS app.
iOS doesn’t allow this kind of file access in general I’m afraid. A workaround is to create a public link to say a file a dropbox or iCloud and copy that into your Agenda notes.
Another thing you can do is select text in your note and hit cmd-K. Then drag the file to the pop up box. You don’t get the name of the file added to the text that way, but I usually type out what I’m thinking about and then link to text I just typed, anyway. So I find this method easier.
