To my shame in Agenda I hit Cmd-S several times per hour. This makes an audible beep each time.
I could train myself to stop, but then I might lose unsaved data in other software
Would it be possible to make Agenda absorb the Cmd-S silently? Or is there something I can do to obtain the same result?
We’ll see what can be done, thanks for the feedback.
You can certainly reprogram that yourself, with a customized shortcut.
What do you suggest I should assign cmd-S to? I haven’t find an appropriate menu item, one that does nothing.
FWIW after more than 6 months using Agenda quite often, I’m still hitting cmd-S several times a day. Pathetic, I know
Every time Agenda beeps at me, as if mocking my useless muscle memory
flo
March 30, 2022, 6:30pm
6
Assign ⌘S to empty bin for example
That would be bad as it would not be what you want/expect. If anything we either make it a forced save, or make it a no-op.
I’ve looked for a menu item that does nothing, so I could assign ⌘S to it, but I haven’t found one yet. It’s actually a good thing
flo
March 31, 2022, 9:25am
9
Other options though it will move the cursor:
As of Agenda 14.1 this is now fixed, thanks a lot
