Deleting a not by the dropdown menu (by right click directly on the note).
The note disappears but not the drop down menu.
The drop down menu disappears before the note disappears.
beta 2.2 (newest version)
Can you send a screenshot of what you describe?
I had one note in a project.
I deleted this note by rightclick and „Delete note“.
The note disappeared, also the menu.
But: The nenu appeared again right after disappearing.
OK, understanding it better now, thanks, will investigate as well.
Ah, found out what the problem is:
I used the right mouse button (the same as to get the dropdown menu) to choose „Delete note“.
This „second“ right click triggered the „Delete note“ AND showing the dropdown menu again.
In Finder it makes no difference if I would use the right oder left button of the mouse.
Another misbehaviour connected to the right click:
- On a note make a right click, do not move the mouse -> The dropdown menu appears.
- Make another right click -> The dropdown menu disappears and a new one appears.
- Make a third right click -> The dropdown menu disappears.
In Finder:
- A right click -> A dropdown menu appears.
- Make another right click -> The dropdown menu disappears.
- A third right click -> A dropdown menu appears.
(which im my opinion is correct)
Ok, that definitely helps to explain things. We’ll see if this can be fixed or whether it’s behaviour provided by the system.
