Example:
boats
beaches
birds
bowboats
If I search for ‘boats’ I want that Agenda surfaces both boats
and rowboats
, instead of only boats
. In other words: The search should be “unanchored”.
Even better: If I search for rbts
, rowboats
should be shown.
Such an unanchored search, that doesn’t insist on direct continuiation would be great. Important: It should also work for parameters of tags:
vessels(boats)
vessels(rowboats)
rbts
should lead to vessels(rowboats)
in this example.
An app that does have the kind of search I’m looking for is the IDE Visual Studio Code when you pres cmd+P
