Working in a note with several levels of heading. Once the heading is set, it’s diffuclt to see at a glance which heading style I’ve selected - making reorganising the structure tricky.
I feel it should be visually obvious from the font size etc, and via a pop up or similar when you mouse over or select the heading. And at the very least, when you right click and navigate to style, there should be a tick to indicate which style is selected.
