What I did: Without selecting any text press command C and then Command V in place.
What happened: The current note you’re on is duplicated.
What I expected: No duplicate note to be created.
Version 9.3
OS Catalina Version 10.15.3
This is intended behaviour, if you have no text selected (and no blinking cursor) the entire note is copied.
Thanks for the reply! I have experienced the entire note being copied when I have text selected. I can’t get it to happen consistently but I move text around a lot and occassionaly it duplicates the entire note.
That’s indeed a bug we’re trying to hunt down, related to the reports of occasionally the cursor jumping to a different location. Unfortunately it’s proving hard to reproduce, so if you do find reproducible steps, or actions where it’s more likely to happen, please do let us know.
Thanks for confirming that I’m not crazy! I’ll keep an eye out
