Do you anticipate that we will be able to connect our notes data to an LLM such as Claude or ChatGPT?
We added this recently. Please see this:
I did not see ChatGPT. Does it mean it’s not supported?
ChatGPT doesn’t offer the possibility to connect to local MCP-servers, so nothing really the Agenda-Team can do. If you want to use the ChatGPT models together with Agenda you’d have to use Codex, either in the Terminal/CLI or the dedicated app
Is there any documentation, examples, etc… available?
The only “docs” we have for now are this post: Agenda Support for Model Context Protocol (MCP)
To connect, I suggest just installing Claude, and then going into Agenda > Integrations menu and choosing the plugin option for claude.
Once you are connected, I would just ask claude what sorts of things it can do via MCP with Agenda. It will explain it to you itself. I knows as soon as it is connected.
