Collecting notes from a variety of topics
I want to collect notes about a particular topic from a bunch of different projects into a project of their own. What is the easiest way to do this?
I’m afraid that if you want to consolidate your many scattered notes in one place, moving or copying them will be a tedious process.
So, you’d have to search for them first and then move them (via drag and drop, text actions, etc.).
In my opinion, a slightly different approach would be this:
I would prefer using the search function and then the save function in the smart overview. The relevant notes would then be easily accessible and grouped similarly to a project.
Thanks. I used your suggestion to search and save the overview. It worked great.
I’m really glad to hear that!
