The key “>” at the start of the line converts it to block quote.
It would be great to be able to select several existing paras and convert them to block quote using Cmd >
I know shift-cmd-6 will work, but I never remember it, and it’s a pain navigating the menu on mac - partly becuase I alway assume Block Quote is on the Indentation menu.
[] doesn’t work for existing paragraphs. If you select text, and then type [], it will simply replace the text. The problem is that when you select text, and then type some text (eg “>”), it replaces the existing text. That is a standard text edit. It would be very odd if we applied commands like that, which is why you need to use CMD or CTRL or whatever.
I think the best solution is simply to go into System Prefs and change the standard key command to one you like, like CMD-> or whatever.
Not trying to be tiresome, but I frequently put the cursor at the beginning of a paragraph that I’ve pasted and type - or [ ] to create a list, or # for a heading.
Wouldn’t > fit logically with this existing functionality?
Just tested, and indeed this does not work. I think that is just a bug or something we missed. Thought you were asking for something different (ie a command).
