It would be great to have tag suggestions available during entry, including search. It would also be great to have the ability to optionally navigate via tags in the left sidebar
+1 for tag suggestion as you fill in a tag
I think you can sort by tags at the moment.
You just need to search for a tag. And it will ask if you would like to save this “searched tag” and it is appear at the side bar.
Yes, but why not auto populate a possibly hierarchical tag structure
+1 here. And please make it all start in the Lower case letter. Because some app are so case sensitive that if I tagged it with a word starting in an Upper case letter, it produces another set of tags.
The app Bear does a really good job of this. Makes it really easy to cross reference and create “buckets” of topics eliminating the need to have a subfolder system like Apple Notes.
We’d indeed like to add tag and people auto-completion in a future update.
Optional sidebar navigation as well please
same here:
- tags with “.” support
- tag suggestions in search
- tag list in left column with count
