Bar divider for Sourcelist
Hiya!
Would be great to add a divider to the left hand side that we could move around.
Can you explain? What sort of divider? Ie what would it divide?
Whatever you want! Something like in the attached screenshot, draggable so that you can place it between any two categories
Curious to hear why you would like to have more explicit spacing/separation between categories?
It adds another potential level to the hierarchy (this makes sense only if you can also manually order your categories / projects).
Got it, it’s probably more likely we’ll allow for subprojects in a future update.
