Automation: propose a RTFD export option
Currently, this is possible to export Agenda notes in Apple Shortcuts in RTF format. However, if the note contains attachments, the RTF file won’t contain it.
I’d like the possibility to export to RTFD, as this is possible on macOS when exporting notes manually.
As mentioned in Automation: export to RTF without Shortcuts , if this format can also be available through MCP, that would be great.
Thanks for the suggestion. It makes sense to bring the Shortcuts export in line with the manual export options, and RTFD would keep the attachments intact. We’ll take it along.
The MCP is trickier, because everything at that boundary is text based right now. Attachment support for the MCP is on our list too.
Glad to read this, looking forward to have this export.
And noted for the limitation on the MCP side.
