What I did: assigning a date from one month through the following month
What happened: it doesn’t allow me to assign across months
What I expected: assign across months
OS Mojave
You can do this by clicking on the start day to select it, then navigate to the end date in the other month and shift-clicking it, that should create a date range that goes across multiple months.
Does the range continue to ‘shift’ forward as Tomorrow becomes Today?
If you save it as an overview (premium feature), you get to choice if you want this or not indeed.
