It’s not mentioned anywhere, but if you select multiple projects (using the Shift or Cmd keys), you see all their notes in a single stream. Now that’s a great idea!
Indeed. Glad you like that!
This is really cool - I was getting annoyed I couldn’t select a Category and see all the projects in it, but this solves the problem.
(I have a category for a single client with three projects in it. I knew I had written a note but couldn’t remember which project it was in!)
