Can someone share how to send Agenda notes to Roam Research?
Agenda & Roam Research are both excellent applications. I use Agenda on the mobile terminal, and then manually copy Agenda content to Roam.
Is there a way to send or synchronize Agenda content to Roam with one click?
There is no sync option, but you should be able to send a link or content using the share extension.
On the Mac, choose Share… in the cog on the note at the bottom. iOS should be the same. You can also share from the yellow dot at the top-left of a note, by using the Other Actions…
