Ability to sync notes over iCloud on a Project or Category basis
Hi there,
Please consider adding more granularity to the ability to sync over iCloud or Dropbox. I’d like to be able to sync some Categories of projects and not all. For example, the ability to keep Categories with sensitive information locally stored only while others are synced over the cloud.
Love using the product!
If we added end to end encryption, would that solve it for you too? Ie you can encrypt a project, so it syncs, but the data is unreadable to anyone but you, with the pass code? (Not even Apple could read it.)
Improved but would prefer the option not to store specific categories in the cloud
I like this solution.
I would very much approve this solution.
